4.3.2611021619, Nov 05, 2026
Templates · Mentions · Panes · ShareTo · API
  • 536/8 #Templates can now fill in your name, email, initials, mention, and the current date or time when used. Add placeholders such as {{user_name}} and {{today}} to your template.
  • 1592/8 Local backup retention now keeps your chosen number of automatic backups, even when days pass between them. Manual backups are never removed automatically.
  • Desktop Quick Add has a more compact layout and grows as you type, up to eight lines before scrolling. Its shortcut can now be enabled or disabled in Settings without restarting the app.
  • With Conversations enabled, profile photos now appear directly in mentions, including in mobile apps. Settings → Personalization lets you choose full names, avatars with initials, or avatars only. Compact mentions show full names on hover and preserve them when copied.
  • 1292/1 Drag a single bullet onto a pane divider to open it in a new adjacent pane without moving the bullet. Double-click the divider between two panes to swap them, keeping their widths and contents.
  • 1470/1 Back and Forward in a pane now restore your previous scroll position, including in search results.
  • 1597/1 Focusing a pane scrolls it into view with less horizontal movement, and closing a pane no longer jumps sideways to the active pane. Pasting into a partly visible item or note preserves the scroll position in panes and board columns.
  • 1348/1 The previous/next sibling shortcuts now navigate from the item zoomed into in the active pane. Reaching the first or last sibling no longer navigates the underlying page.
  • The New pane button stays visible when you scroll across panes, and the sidebar button no longer disappears during pane navigation.
  • 1611/1 Restored the shortcut and star buttons in pane search boxes, so you can assign a shortcut or star the search shown in that pane.
  • Pane resize handles no longer block scrollbars or stay highlighted after you finish resizing.
  • 1615/6 Improved performance when editing and moving items in panes, and when searching outlines with mirrors.
  • iOS ShareTo now uses native UI, lets you retry failed saves, and opens Workflowy to sign in again when your session expires. Shared text uses the complete first line as the bullet and the remaining lines as children. The duplicate “Save to Workflowy” action has been removed.
  • The iOS app now recognizes existing paid subscriptions and hides the upgrade prompt, preventing an accidental second subscription.
  • Fixed clipped page titles, blank screen edges, and excessive indentation when using the iOS app in landscape.
  • Opening the weekly report no longer risks losing stars or settings changed at the same time, or triggering an unexpected reload.
  • Approved faculty now get a one-time welcome with a button to open their Faculty dashboard, and no longer see the education application prompt.
  • Help links now open the matching documentation topics in the Workflowy Community, and existing help URLs redirect there.
  • The API reference now explains how to create an API key, make your first request, and connect AI tools through Desktop MCP.
  • Dialog titles now use smaller text, and sidebar shadows sit outside the panel.
