Use focused AI commands to transform content in Workflowy.
AI Quick Actions run premade prompts directly on a node, without the need to type anything. They are convenient and reduce the need to switch between Workflowy and another tool.
Note: AI Actions require a Pro subscription and Workflowy AI to be enabled in the Settings.
Use AI Quick Actions
- Place your cursor on the node that contains the content you want to perform the action on
- Type
/aito see all the quick actions available - Pick one
Available actions
- AI: Summarize condenses the selected content.
- AI: Find tasks identifies actionable items.
- AI: Draft an outline turns source material into a structured outline.
- AI: Fix grammar & spelling edits writing while preserving its meaning.
- AI: Make shorter creates a more concise version.
