I use the public API to put my calendar calls into day bullets on my timeline. Bullets the API creates start collapsed, so I open each one by hand to see the calls inside.
Could the API let us set and read whether a node is expanded? For example, an expanded field on create, update and get.
Another use for this: I’ve got Claude Code writing project summaries to the top of my bullets through the API and the wf CLI, and they land collapsed too, so I’m opening those by hand as well. An expand/collapse command in wf would be great alongside the API field.
I know expanded state doesn’t sync across devices at the moment, so I’m not sure how that fits in. Even if it only set the default state a node opens with, that would be enough for me.
