Is there a reason why (on MacOS using Native app) CMD+F doesn’t just put you into the Find window? Seems like a behavior that is pretty darn near universal across other apps…
Presumably compatibility with the web app, which AFAICT is overwhelmingly what most people use, and for which the browser, not WF, retains the “Find” keystroke?
Meh. I mean there’s a reason why I want to use a native app and that’s because I want the superior experience it can provide… which comes from doing little things like this.
Understood.
FWIW, I find Ctrl+semicolon almost as easy to type as Ctrl+F
Not fond of this default myself, but FYI you can set this shortcut using the command palette ( Command Palette | Workflowy Help ) and then selecting customize_hotkeys. Add this to that note:
* meta+f
* focus_search
