Is this intended behavior? Other Alt Clicks seem to open a pane to the right of the originating pane. Just wondering if that is what this should do.
Could you check again in a browser please? It should be fixed.
Confirmed working (open in new pane), though if the click is on a WF date, then nothing happens, which is a different bug.
Well Ctrl+Click does open the link in the node in the pane to the right, thanks. Though didn’t it use to be a Ctrl+Click on a WF date would search in context for that WF date per @jodmarch?.
Now 2 combos do the same thing relative to opening a link in the pane to the right. Did you ever consider only using Ctrl+Click for the links opening as it works “similarly” (opening something) for the context searches of WF dates and tags? Alt+Click on WF dates and tags deletes them from the node. Sort of counterintuitive Alt deletes in one instance and creates in the other.
