Date Change Not Updated in Right Panel of Split View
In the split view with the calendar view, when the date is changed for an item in the right panel, it does not update and move to the new date automatically. This does work in the left panel. I like my calendar view on the right and would appreciate if the auto update would work there, too.
Thanks, @john . Confirmed in 4.3.2609180341 [beta, edge, win]
Please repost this in subcategory Latest Issues & Ideas/WIP: Panes topics - Workflowy and tag with “Bug”, and then delete here to avoid duplication.
(This is one of many instances of inconsistency bugs between pane 1 and other panes (NB they use the word “pane”; they use the word “panel” to refer to the left node index (Alt+L) panel and the right Help panel (Ctrl+?))
