[Feature request] Add an “Open Original Nodes in Pane” Toggle
To accommodate different workflows and user preferences, I suggest adding a toggle option to the Settings menu labeled “Open Original Nodes in Pane.”
Current behavior:
When a user Alt+clicks a mirror node, the mirror node opens in a side pane.
Proposed behavior:
When a user Alt+clicks a mirror node, either the mirror node or its original node opens in a side pane, depending on the selected setting.
  • Toggle OFF (default): Opens the mirror node in the side pane, preserving the current behavior.
  • Toggle ON: Opens the original node in the side pane instead.
This would provide greater flexibility while maintaining backward compatibility with existing workflows.
Thank you for considering this suggestion!
Out of interest, why does it matter which version of the mirror opens?
