Hi WorkFlowy Team ,
Love the new Panes feature! Being able to double-click the middle divider to reverse/swap the pane positions is a fantastic touch.
To make pane management even smoother and consistent with macOS navigation standards (and building on the column/kanban resizing request), it would be great to see standard Option-key modifier shortcuts implemented for the middle pane divider :
Click here for more details...
Proposed Shortcuts & Mechanics :
Option + Double-Click (on pane divider)
Option + Drag (on pane divider)
Why this helps :
Workflow Continuity : Eliminates manual fine-tuning when switching between deep nested outline views and high-level structural overviews.
UI Consistency : Pairs naturally with existing standard desktop interactions and expands upon the native double-click-to-swap mechanics already present in Panes.
Thanks for continuing to refine the Panes feature!
