[Feature request] keyboard shortcuts for opening a node in a pane
Currently, there is no way to open a node in a pane without using the mouse.
In particular, “jump to” really needs a keyboard shortcut for opening the selected node in a pane.
Using tab to move the focus is not ideal. Once I have moved the focus to the button, I am not able to type at all.
I might be misunderstanding your request, but I do this with keyboard only, as follows:
Type the filtering characters, then use the up and down arrows to select the desired node. You can keep typing while using the arrows if you want to narrow the filter more.
After the right node is selected, use the tab key to select the “new pane” button as indicated in your screen shot. Note: only use the tab key AFTER you have already selected the desired node.
Press Enter to open that node in a new pane.
Nice trick.
Thanks. I don’t actually think it’s a trick; I think it’s the UI as sensibly designed, just not adequately discoverable or documented.
This is what I was describing, but it is not idea. Using tab to move the focus is usually my last resort to handling UX in a GUI app as a keyboard-focused person.
Since enter is to zoom in a node, I feel alt-enter can be used to open a node in a pane.
I think you mean “not ideal”? Maybe, maybe not.
Your instinct is reasonable. You want to treat the node entries in the list as separate fields. But it’s also arguable that the entire list is a single field, and that arrows are the right way to navigate it.
Bottom line – the entire process can be done from the keyboard, in a plausible way. So there’s not actually a problem, just a preference.
