Files and images
Learn to upload files and images anywhere in your Workflowy documents.
When to use
Files and images in Workflowy let you keep everything in one place. Just drag and drop to upload PDFs, screenshots, photos, or any other file right into a bullet.
You can preview images and documents directly inside your outline, or download them when needed.
It’s perfect for storing references, sharing assets, or adding visual context to your notes - no need to jump between apps.
Upload limits
Free users can only upload 100mb of files, while Pro Subscribers enjoy unlimited uploads with a 5GB file size limit. All accounts can upload a maximum of 15 files per minute.
Add a file or image
You can add files and images by dragging and dropping them into Workflowy, from the bullet menu, or with the slash command “Upload file”.
  1. Click and hold a file or image from your computer
  2. Drag it onto your Workflowy window
  3. Drop the item where you want to place it
files-drag-and-drop
Resize an image
You can resize any image you upload.
  1. Move your mouse over an image
  2. Click-and-drag the vertical bar to the left to make the image smaller or drag the bar right to make the image larger
files-resize-image
Set default image size
You can set the default image size of new images.
  1. Open the settings menu from the menu bar
  2. Under the “Images” section, you can choose either big or small thumbnails
files-thumbnail-size
View image options
Images have several options that you can access from the image menu. The options are: Show full-screen, view original, download, settings.
  1. Mouse over an image
  2. Click on the image options button
files-image-options
Delete a file
  1. Mouse over the bullet that has the file
  2. Open the bullet menu for the item
  3. Click on “Delete”
Download all files and images
  2. Under the “Backup” section, choose “Download Files”
This will open a new page where you can create new zip files containing all your files and images and also download previous zip files. Once you’re on the Downloads page:
  1. Click “Prepare New Download”
This will start the download preparation process. You can now close this window. Once we’ve gathered all your files and images, you’ll receive an email.
Once you receive an email from us with the subject line ‘Your Workflowy File Is Ready for Download’, your download is ready.
  1. Click ‘View your Downloads‘ in the email
This will open up a page where you can download the zip file that contains all your files and images. On the downloads page:
  1. Click the “Download” link for the file you want to download
View PDF files
You can view pdf files inline by dragging and dropping them into Workflowy.
  1. Drag and drop your PDF file where you want it to be
  2. Click the cover of the PDF file to preview it
  3. Scroll down to view the contents
  4. Click outside the PDF or the ‘X’ in the top right corner to close the preview
pdfs
