Filter out links from link suggestion dropdown
When I create a new link using [[ a dropdown gets shown suggesting nodes to link to. Now I want to find say “HOME > SOMETHING”, so I type “[[SOMETHING”. On the screenshot below I can see what it suggests. And in the list there are also “links pointing to the same node” listed - I don’t want that.
The problem is, that sometimes all the other links (e.g. under Calendar), show up higher in this dropdown before the node I actually search for (the “HOME > SOMETHING”), so I have to scroll down a very long list of useless suggestions (I practically never want to link to link to a node, always just to the final node). I suggest to filter out the “already links” from this dropdown entirely OR at least add a toggle to not contain them there! I think it would really improve usability of [[ links. To me at least.
Also now I noticed a BUG, while creating the example above. The “<” character in the node’s text breaks the label in the dropdown list: the “<” character and everything after it is missing in the label in the dropdown. When I remove the “<” character I can see the whole text of the node in the dropdown again:
