I use the multi-pane layout and try to drag one pane to make it as wide as a normal single-pane view.
But if I delete/cut some texts or paste some texts, the screen does not stay anchored near the current writing position or cursor. It just goes up .
If you cannot reproduce, I can provide the clip.
artem
(Artem D)
October 21, 2026, 3:23pm
2
Hi Victor, thanks for the report. Could you please share a video recording?
jodmarch
(JM)
October 21, 2026, 10:57pm
5
I don’t see this in 4.3.2610211815 [beta, edge, win].
Also, I’m puzzled why the description says “drag one pane to make it as wide as a normal single-pane view” but that doesn’t seem to be the case in the video.
artem
(Artem D)
October 22, 2026, 2:59pm
7
@vlad
I just found out that if I delete some texts, the screen still behaves like I mentioned that the screen simply scrolls up. tested in the newest beta.
If you are unable to reproduce the behavior, I can record a video clip.
vlad
(Vladyslav Yanko)
October 23, 2026, 3:25pm
10
Could you please share a screen recording showing the issue?
More precisely, if you delete the line break, the screen goes up; if you add the line break, the screen goes down.
4.3.2610231329 [beta, chrome-152, mac]
@vlad
