The close_pane command should work on the current pane (the one with the blue line) without requiring a mouse click to get focus. (This just seems sensible since no specific node or text needs to be specified; it is also more pressing because the pane frequently loses focus unnecessarily after many commands.)
Works fine now on beta and prod.
