[FIXED!] Pane search bugs
  1. In a pane, when a search is active, and I create a new node by pressing Enter, the new node is never shown because it does not meet the search criterion. This is both confusing and contrary to the expectation set by the primary pane.
  2. In a pane, Escape opens the search field but after the search, Escape does not end the search.
In a panel, Escape opens the search field, but after the search Escape does not end the search.
Just FYI…this is a bit of a nuisance for me as well.
Both bugs are fixed in 4.3.2608181525 [beta, edge, win].
Thank you!
