Getting focus to pane 1 via clicking
You have to click into the node area of Pane 1 to get focus there. In every other Pane you can click below the nodes and focus will change, If you do that in Pane 1 the blue line will flash and go away.
Confirmed. For me, the blue line flashes and goes to another pane (random? Mostly pane 3, but pane 4 if I’ve moved pane 3 to the right).
By the by, the CP hotkey for focus_or_open_pane_1 does create focus in Pane 1.
Fixed on beta.
Confirmed fixed
