IMPLEMENTED! : After moving , Shift+Enter view should intuitively jump active new pane s instead of left‑most pane
I am now organizing nodes in new panes. After I use “Move to” to move a node to another location, it shows “View: Shift + Enter.” When I trigger this action with Shift + Enter, I expect the new pane to jump to that view.
However, instead, the leftmost pane jumps to the view, which is counterintuitive.
So I hope that after using “Move to,” pressing Shift + Enter will make the new pane jump to that view.
