Instant presentations
Learn to instantly turn any outline or document into a simple and clean presentation.
When to use
Presentations in Workflowy let you turn any outline into a clean, minimal slideshow - one bullet at a time. Just hit the present button (play button) to walk through your content step by step, focusing attention without distractions.
It’s perfect for meetings, lectures, or sharing ideas in a structured way, all from the same outline you’re already using to think and plan.
How presentations work
In presentation mode, clicking the “next” button or using the right arrow key will navigate your bullet list in the following way:
A. The topmost bullet will become the title of the presentation
B. Each nested bullet will become a slide
C
. Bullets nested under these slides will become bullet points
Make a presentation
Presentation mode only changes how content is displayed and so can be used with all your existing lists. Once you exit presentation mode, any edits you made will be available.
  1. Create a bullet to hold your entire presentation, this is the presentation title
  2. Nest bullets under the title to create slides
  3. Nest bullets under each slide item to create bullet points
View a presentation
  1. Click on the bullet point that is the title of your presentation to zoom into it
  2. Click the play button in the menu bar
  3. Use the left and right arrow keys on your keyboard or click the buttons on the bottom right to navigate the presentation
  4. Click the “X” button in the top right to exit out of presentation mode
