Navigate, edit, and reorganize your Workflowy faster
Keyboard shortcuts let you run common actions without opening menus. The shortcuts below are Workflowy’s defaults.
Default keyboard shortcuts
The following are Workflowy’s default shortcuts. Your active shortcuts may be different if you have customized them.
Some browsers and operating systems reserve particular key combinations. Open the Keyboard Shortcuts panel inside Workflowy to see the active shortcuts for your device.
Navigation
| Action | Windows and Linux | macOS |
| Zoom in | Alt+. |
Command+. |
| Zoom out | Alt+, |
Command+, |
| Go to Today | Alt+T |
Control+T |
| Navigate home | Ctrl+' |
Command+' |
| Jump to any item | Ctrl+K |
Command+K |
| Previous sibling page | Alt+Shift+9* |
Command+Shift+9 |
| Next sibling page | Alt+Shift+0* |
Command+Shift+0 |
| Focus previous sibling | Alt+Ctrl+↑ |
Option+Command+↑ |
| Focus next sibling | Alt+Ctrl+↓ |
Option+Command+↓ |
| Search or exit search | Esc |
Esc |
* Linux uses Ctrl+Shift+9/0.
Editing and moving items
| Add a note | Shift+Enter |
Shift+Enter |
| Complete | Ctrl+Enter |
Command+Enter |
| Duplicate | Alt+Shift+D |
Command+Shift+D |
| Delete | Ctrl+Shift+Backspace |
Command+Shift+Backspace |
| Copy as mirror | Alt+Shift+M |
Command+Shift+M |
| Copy link | Alt+Shift+L |
Command+Shift+L |
| Move to another location | Alt+Ctrl+M |
Control+Command+M |
| Indent | Tab |
Tab |
| Outdent | Shift+Tab |
Shift+Tab |
| Move up | Alt+Shift+↑ |
Command+Shift+↑ |
| Move down | Alt+Shift+↓ |
Command+Shift+↓ |
| Expand | Ctrl+↓ |
Command+↓ |
| Collapse | Ctrl+↑ |
Command+↑ |
| Expand or collapse | Ctrl+Space |
Control+Space |
Formatting
| Bold | Ctrl+B |
Command+B |
| Italic | Ctrl+I |
Command+I |
| Underline | Ctrl+U |
Command+U |
| Strikethrough | Ctrl+Shift+X |
Command+Shift+X |
| Inline code | Ctrl+Shift+C |
Command+Shift+C |
| Apply last highlight color | Ctrl+Shift+H |
Command+Shift+H |
| Link selected text | Ctrl+K |
Command+K |
Item types
| Heading 1 | Alt+Ctrl+1 |
Option+Command+1 |
| Heading 2 | Alt+Ctrl+2 |
Option+Command+2 |
| Heading 3 | Alt+Ctrl+3 |
Option+Command+3 |
| Paragraph | Alt+Ctrl+4 |
Option+Command+4 |
| Code block | Alt+Ctrl+6 |
Option+Command+6 |
| Quote block | Alt+Ctrl+7 |
Option+Command+7 |
| Bullet | Alt+Ctrl+8 |
Option+Command+8 |
| To-do | Alt+Ctrl+9 |
Option+Command+9 |
| Numbered list | Alt+Ctrl+0 |
Option+Command+0 |
| AI Node | Alt+Shift+Space |
Option+Shift+Space |
Panels and visibility
| Show or hide completed items | Ctrl+O |
Command+O |
| Star current page | Ctrl+Shift+8 |
Command+Shift+8 |
| Toggle left sidebar | Alt+L |
Control+L |
| Toggle Keyboard Shortcuts panel | Ctrl+/ |
Command+/ |
| Open Command Palette | Alt+W |
Option+W |
| Export | Alt+Shift+E |
Command+Shift+E |
| Open or close AI Chat | Alt+C |
Control+C |
| Presentation mode | Ctrl+Shift+P |
Command+Shift+P |
Panes
| Action | Windows | Linux | macOS |
| Open a new pane | Alt+R |
Alt+R |
Control+R |
| Focus or open pane 1–8 | Alt+1‑8 |
Alt+Shift+1‑8 |
Control+1‑8 |
| Open item in pane 1–8 | Alt+Shift+1‑8 |
Ctrl+Shift+1‑8 |
Control+Shift+1‑8 |
| Close active pane | Alt+Ctrl+W |
Alt+Ctrl+W |
Control+Command+W |
Collaboration and unread items
| Add a comment | Ctrl+M |
Control+M |
| Mark as read | Ctrl+Shift+Enter |
Command+Shift+Enter |
| Previous unread item | Alt+Ctrl+P |
Option+Control+P |
| Next unread item | Alt+Ctrl+N |
Option+Control+N |
System
| Save and sync | Ctrl+S |
Command+S |
| Undo | Ctrl+Z |
Command+Z |
| Redo | Ctrl+Y |
Command+Y |
| Redo alternative | Ctrl+Shift+Z |
Command+Shift+Z |
Ctrl+P |
Command+P |
Customize keyboard shortcuts
If you customize a shortcut, the Keyboard Shortcuts panel and Command Palette will show your current assignment instead of the default.
During the current gradual rollout, custom keyboard shortcuts are available to Pro users with Workflowy Labs enabled.
To customize your shortcuts:
- Enable Workflowy Labs in Settings.
- Open the Command Palette with
Option+Won Mac orAlt+Won Windows and Linux. - Search for
customize_hotkeysand pressEnter. - Under the special Custom → Hotkeys item, add the key combination as a bullet and the command name as its first child.
For example:
alt+q
show_command_palette
You can find available command names in the Command Palette. They appear in lowercase with underscores, such as duplicate, move_to_today, or toggle_bold.
Writing key combinations
Write modifiers in this order:
alt+ctrl+meta+shift+[key]
Use lowercase characters. On Mac:
altmeans Optionmetameans Commandctrlmeans Control
How custom shortcuts behave
- Assigning a custom shortcut to a command removes that command’s default shortcuts.
- Remove the custom binding to return to the command’s defaults.
- If the same key combination appears more than once, the definition lowest in the Hotkeys list wins.
- Only commands available in the Command Palette can have their shortcuts overridden.
- Changes take effect as you edit the Hotkeys list.
