Learn to use multi-factor authentication to protect your Workflowy account.
When to use
MFA (Multi-Factor Authentication) in Workflowy adds an extra layer of security to your account by requiring a second verification step - typically a 6-digit code from an authenticator app.
Even if someone has your password, they can’t log in without this code. Setup requires saving recovery codes in case you lose access to your device.
It’s a powerful way to keep your data safe and your account protected.
Turn on MFA
Please note: Please make sure you understand how MFA works before turning it on. If you don’t follow the instructions correctly, you run the risk of losing access to your account if you lose access to your authentication device or recovery codes
We recommend Authy, 1Password, or LastPass for your authenticator app. We do notrecommend Google authenticator.
During the setup process, you will be asked to save recovery codes. If you lose access to your authentication device, these codes are the only way to log back into your account so please save them.
- Choose and download an authenticator app
- Click the options button in the menu bar
- Click the “Settings” option
- Toggle the “MFA” setting
- Enter your password and click “Confirm password”
- Click on “Setup MFA”
- Copy and save your recovery codes somewhere safe
- Click the “Next” button
- Open the authenticator app you chose
- Scan the QR code using your authenticator app
- Enter the six digit number code from your authenticator app
- Click the “Close” button
Turn off MFA
- Click the “Disable” button
View recovery codes
You can access your recovery codes after the MFA setup process from the settings panel.
- Click the “Show recovery codes” button
- Copy, print, or download the new recovery codes
Generate new recovery codes
Please note: This will render any current recovery codes useless, so be sure to save the new ones you generate.
- Click the’”Settings” option
- Click the “Get new codes” button
- Click the “Ok” button
