Newish Alt and Ctrl Click on internal links
Personal opinion this has become a dog’s breakfast. Is anyone documenting what to expect when one clicks on a local link in Workflowy? Whether it be a straight click, a shift click, a control click, or an alt click. Clicking on a link and having the screen separate into different windows, some of which are on screen, half on screen, off-screen, is just not a good look. Poor usability for me. What was wonderful in panes is now a pain in the a$$.
It is very discordant. Maybe it’s a design thing as opposed to a bug, but I needed to report it somewhere.
In 4.3.2610211815 [beta, edge, win], click opens in same pane, Ctrl+Click and Alt+Click open in new pane just to the right of current pane. (I thought that one of them opened in a new far right pane, but I’m not seeing that now.).
The very new thing that I’m seeing, which appears to be a WIP experiment, is that Ctrl+Alt+Click and Ctrl+Shift+Click are now splitting the screen in half, re-fitting the existing panes weirdly in the left half, and opening the link in the right half.
I remember initially when you opened a new pane, all panes including the new one were adjusted to the same width. If you added more panes than would fit in the Workflowy tab, they sort of scrolled off to the right out of view, but you could get to them.
Now, Prod and Beta, all with 2 panes open, each with half the tab.
Click or Shift Click opens the link in the same pane. Fine.
Ctrl+Click and Alt+Click open the link in pane 3 which is half the width of pane of 2 (the text wraps in pane 3), pane 2 is the same width, pane 1 is the same width but only the right bit is visible. Found this out by using CP to go to pane 1. Do it again, and a smidge of the left of pane 4 appears in the tab (and I think pane 3 narrows). All with no scroll bar. A dog’s breakfast.
It seems that the only problem is that with your browser, WF is not drawing the scroll bar. I think that I see what you see, except that there IS a scrollbar, so panes “disappearing” to the sides (e.g. “pane 1… only the right bit is visible”) is as expected & desired. After adding new panes at the right, I can see all of pane 1 by scrolling left or by selecting pane 1 (default hotkey is Alt+1)
I will check the browser tomorrow.
Relative to expected and desired we have different opinions. The mish mash of pane sizes doesn’t do much for me. I would prefer the pane sizes be the same. But that is me and my use case.
I agree that if all existing pane widths are the same then that says something about the user’s preference and a new pane would ideally be the same. If they vary then I don’t see any obvious “right” choice. Bottom line, I don’t care what is the width of a new pane, because I can adjust it with a quick swipe of the mouse. Now that they scroll horizontally, a much wider range of widths is usable.
(Although some (not I) might argue that if all existing panes fit in the window without scrolling, then that is characteristic that should be preserved, rather than the width of each panel.) ¯\_(ツ)_/¯ )
I am OK with the pane sizes changing to the same size to fit in the tab (1/# panes width) and when the minimum pane size is reached then add the panes to the right, virtually. As it was in the early days version to the best of my memory.
I have to fiddle with the panes or scroll in this new process. I did not have to in the original process. I prefer not to fiddle.
Video on wide screen view to accentuate the craziness. See in Slack.
