Nodes collapse after using move pane
I have two panes open and some of the nodes are expanded in Pane 1. If I move Pane 2 left via the hotkey, when Pane 1 becomes Pane 2 the nodes are collapsed.
Pane 2 → pane 1 then collapse
Reproduced
Fixed on beta.
Does not work on Beta when the nodes have been expanded in a search.
Perhaps related to Bugs: Search results in the leftmost pane show "still searching’ while moving the pane, unlike other panes - Issues & Ideas / WIP: Panes - Workflowy
IMO, moving a pane should change nothing about it except its location on the screen (and of course its sequence number within the window, i.e. pane 1, pane 2, etc.)
Same reply as in the other thread
