Panes on mobile (swipe between them)
Now that we are all spoiled rotten by panes, it would be great to have similar capability on mobile. I’m thinking that one pane would be visible at a time (assuming basic 1-screen mobile) and that we could swipe between them. Since swipe on mobile is already well defined, this might require something like a multi-pane swipe bar at the top or bottom of the screen.
I’ve occasionally used mirrors in a parent node to do something similar, but that’s really not as quick and intuitive.
As a subsequent enhancement, perhaps something like DnD between mobile panes could be implemented. That would take some thought, but perhaps the multi-pane swipe bar could serve as the magic channel between panes for this.
