Will there be a passkey sign in capability in the near future? Most services I use have now adopted this technology. When will this be available for Workflowy?
you mean the Passkey in the MFA or a different thing?
Yes, I mean password-less authentication login.
Just to make sure we’re on the same page, do you mean passwordless sign-in, like Google, Amazon, or PayPal offer, where you use a passkey instead of entering a password or an emailed login code?
For example, the passkey could be saved on your device or in a password manager such as Apple Passwords (iCloud Keychain), 1Password or Bitwarden. You’d approve sign-in using Face ID, a fingerprint, your device PIN, or by unlocking your password manager, depending on your setup.
Is that the experience you’re looking for?
Yes, that is correct. Password-less sign in using stored Passkeys in a password manager that is activated by biometrics etc is exactly the experience I am looking for. However, not only is it the “experience” I am looking for, but it is also the modern security technology I would expect from services keeping on top of security. As mentioned, many services I use are switching to this and so I was curious to know when Workflowy would be following suit?
