Peek option: see preview of first 2 or 3 children in collapsed nodes. Would be great in panes, efficient view of contents
an option next to ✓ (show completed), maybe an eye ◎:face_with_peeking_eye: or keyhole icon. When browsing or searching through a large list with sublists that have many collapsed nodes, it would help to see a preview of the top items in collapsed nodes without needing to open (and re-close to keep things tidy), saving a lot of clicking. It would serve as a visual indicator similar to the darkened node showing there are items within, and this would also serve to prioritize top things in these lists knowing they will be peek-able.
I would like to see it under the main text as another type of comment if enabled, as a slightly different style (ie smaller text, greyed style).
  • main text of parent
    comment beneath
    • child 1 text
      • grandchild, child 1
    • child 2 text
    • child 3
Then when you collapse the node you would see the preview underneath like this, similar to a comment to the node.
:small_blue_diamond:main text of parent
comment beneath
child 1 te.. child 2 te.. child 3
If the node is wide, you could see more child text, if the window or pane is narrow it would truncate child text as shown. This would be great in Panes to efficiently show items in a narrow format.
What about if the preview only showed as a hover-card / pop-over / tool-tip when the mouse hovers over the collapse/expand triangle?
Thank you for taking a look! That would be helpful as well, and perhaps be a ‘middle’ option to the peek button. Since our eyes can travel faster than a mouse, an option to see all would still be useful as a ‘full’ option.
I wanted to add, I use panes as a kanban for to-do lists and try to focus on the ‘today’ pane by hiding the other columns so everything else is not so distracting. A peek option would help me keep focus on ‘today’ with those other panes closed and still see the top items of what is hidden.
As with the screenshot, many lists are too long for panes, and I only need to see the next few items, so this would be a much more efficient use of pane space since I quickly lose room in the limited height. With next items / priorities of long lists are towards the top, having a peek option would help me keep focus, and everything important but hidden could still be available ‘at a glance’.
I realize that I can click to open these long lists, or just scroll easily, but peeking into all at once would be a more powerful level of control.
I really value efficiency, and wf is great to scratch that itch.
Update: I mistakenly said ‘panes’ when meaning this would make a more efficient use of boards
