Plan with Calendar
A dedicated space for daily notes, planning, and journaling.
Calendar gives you a daily note for every day, automatically. It removes the friction of having to create and name a new note each morning so you can focus on capturing your thoughts rather than organizing them.
Open today’s note by clicking the calendar icon in the menu bar, pressing Alt+T on Windows or Ctrl+T on Mac, or tapping Today in the mobile navigation bar.
Found Dates
The calendar surfaces Found Dates from anywhere in your account alongside your daily notes, so you can see what’s coming up without having to search for it. You can drag any Found Date onto a calendar day to move it there.
Moving items to a date
Use /Move to today to send any item straight to today’s note. For moving to tomorrow or next week, use /Move to tomorrow or /Move to next week. For any other day, /Move to date lets you pick a specific date.
All of these are also available from the item menu, and work across multiple items at once via the multi-select menu. Useful when you’re rescheduling a batch of things in one go.
Calendar Settings
You can adjust which parts of the calendar are visible and how dates are displayed across the app. Both settings are accessible from the date picker within any daily note.
If you already have items with date tags elsewhere in your document and want to bring them into the calendar, you can migrate them by moving them under the main calendar item and clicking Update in the calendar settings.
