Set quotations and referenced passages apart from surrounding content.
You can format text into quotes to indicate when you’re referring to something someone else wrote or said.
Create a quote block
- Start on an empty bullet
- Type
>followed by a space - Type or paste your content
- Press Enter twice to leave the quote block
Slash command: You can create a quote block with the ‘/quote’ slash command.
Search operator: Quote blocks also come with their own search operator ‘is:quote’. You can use this to filter all quote blocks.
Convert several bullets
Converting several bullets into one quote block combines their content with line breaks. Changing the quote block back into bullets separates those lines again.
