Sync your reading highlights from Readwise into Workflowy.
Readwise collects highlights from books, articles, tweets, podcasts, and other reading sources. Connect it to Workflowy to bring those highlights into a structured outline automatically.
Connect your Readwise account to sync your highlights from books, articles, tweets, and podcasts into Workflowy.
Connect Readwise
You need a Readwise account and a Readwise access token.
- Open readwise.io/access_token.
- Create an access token and copy it.
- Open Workflowy’s Readwise settings.
- Paste the token into Readwise access token.
- Select Connect to Readwise.
- Workflowy creates a Readwise item in your Workflowy account.
Keep highlights in sync
Workflowy checks Readwise every hour for new highlights. To request an update sooner, return to Workflowy’s Readwise settings and select Sync now.
Previously imported highlights are not duplicated.
Disconnect Readwise
Open Workflowy’s Readwise settings and select Disconnect. Existing content remains in Workflowy, but new highlights stop importing until you reconnect.
If Workflowy reports that your token is no longer valid, disconnect Readwise, create or copy a valid token, and connect it again.
