Per the title, if you do a search in multi pane it is significantly slower than if you do the exact same search in single pane. For me anyway. Not sure why that would be.
Hi Cal, thanks for the report, we’ve made some changes to pane search, can you try it on https://beta.workflowy.com/ and let us know if it’s any better.
Much faster, thanks. Later today I will create one of my five pane bookmarked searches in Beta and see how that does. Will advise then. Optimistic from what I just saw. Thanks again.
@artem It took an extra sec to build a test in Beta based upon the confusion with how incremental panes get opened. But once I got them opened i actually had six panes in the search.
I bookmarked it, went to a single pane, and clicked the bookmark and the six panes of results appeared lightning fast.
Then I created a three-pane search view and toggled between the six-pane and the three-pane and it was lightning fast. .
Not a whole bunch of testing, but in all tests no wait at all. Previously, it could be upwards of fifteen seconds before all panes displayed.
Most excellent work. Thank you.
