Side scrolling with panes
I have a really hard time how widening a pane works since the last update: It’s annoying if I want to widen one pane and half of the other pane just disappears on the side so I hav to sidescroll the whole screen. Now I have to adjust it manually every time when working on my small Macbook Air screen. I preferred the other pane getting squeezed and, if it was to narrow, to just sidescroll in that pane. Could you add an toggle option for that?
Really interesting to see, here and in Slack, the big difference in opinion about what should happen when a new pane is added – between those like Adrian and Calsi who find the widening into scroll mode frustrating, and those like me who appreciate it, because we do not want our existing pane widths messed up.
I am not visualizing an intermediate solution that will work for everyone, which makes me lean toward a toggle option as Adrian suggests, even though it’s generally preferable not to add a new option for every UI issue.
P.S. WF team, I see you’ve just reorganized the forum. Is this the sort of discussion that you would like to be in “Ideas” or in “UX”?
UX. There’ll also be an official topic for this specific problem where we’ll try to align with the community on the correct approach (or a toggle).
