On a scale of 1 (useless) to 5 (useful), how useful has Panes been for you?
What’s working well, and what could we improve?
6 - transformative (along with Command Panel (CP), and Calendar with Found Dates)
What’s working well with Panes:
Panes wish list:
Frustration:
Panes have been transformative in how I use WorkFlowy, so I would definitely give them a 5 out of 5 rating! I find them especially useful in the Calendar node for weekly and long-term planning with multiple displays. I completely agree with Jonathan March’s wish list and would love to see panes offer the same functionality and consistent behaviour as using WorkFlowy without panes.
THIS : https://community.workflowy.com/t/survey-how-useful-has-panes-been-for-you/1615/29?u=bxc
AND
THIS : https://community.workflowy.com/t/survey-how-useful-has-panes-been-for-you/1615/32?u=bxc
5, but still have bugs unfixed.
A 10 out of 5. Panes have really enhanced my use case in Workflowy. Particularly the visibility of multiple parts of my outline at the same time. The ability to bookmark the different layouts that I use. My use case is to go to a specific layout. do whatever, and then return to my base two pane layout via bookmarks. Another benefit is not quite search nodes with multiple searches side by side.
Ideas for improvement.
All that being said, Panes is a great bit of technology. Thanks for that.
5: gone is the psychic pain of jumping to grab something from another part of my outline only to forget why I jumped there or where I needed to go back to.
yes this exactly! I love not having to switch back to the other part of the outline
Transformative at a 5 for me too. Panes have been a WONDERFUL addition.
I love:
For example, some of my saved layouts:
Menu planning - 3 panes showing my “master recipe list”, Weekly MENU plan, and Weekly calendar.
Daily View - “Today”, “This Week”, and a flex pane for navigating to projects, lists, other info as needed.
Weekly Review - my weekly review checklist, the weekly calendar, and a flex pane for checking projects, etc.
Improve:
Reduce the “jumble” effect of adding new panes.
I don’t like the current behavior of adding new panes - they add to the right, change the widths of things, scroll off screen… It results in things feeling messy, and like my information is moving around and won’t “stay” where I put it. The visual of the screen is always changing, meaning I need to “hunt” for my information.
I really miss being able to open a link in an EXISTING pane instead of a new one.**
In the “first draft” iteration (side panel) - the side panel stayed static and anything clicked opened in the “main” view. This behavior was unexpected, but turned out to have been HIGHLY useful for me.
When panes first debuted, a shift+click would open an internal LINK in the left-hand pane. This continued to allow me to keep a “daily overview” pane open and static while navigating to other parts of my outline.
I guess both of those boil down to: Just “open in new pane” can quickly become a jumbled mess of TO MUCH. I really like being able to see multiple panes - but I’d like better ways to keep them “neat” and visibly predictable, rather than adding “new panes” that cause things to shift and scroll.
Shift+click did this for me. I developed pane layouts for most of my use cases that had one or two “main” panes that I kept static, and then one “flex” pane that I used to navigate to specific information.
The panels are a great feature, but in Yandex Browser, Alt+R works as the built‑in automatic text correction. In WorkFlowy, I use auto‑correction of phrases all the time. So it would be great to change the shortcut so there’s no conflict. Or add the option to disable or change this shortcut directly in the settings.
5/5. Panes has become a fundamental and stable part of my workflow.
I almost always keep my Inbox open in one pane alongside my Lists view in another. As part of my GTD workflow, this makes it much easier to clarify incoming items, decide what they mean, and move them to the appropriate project or list without constantly navigating back and forth.
The biggest benefit for me is reduced friction during processing and organization. It feels natural now, to the point that I would struggle to go back to working without it.
We are working on custom hotkeys and general configurability of the app, so stay tuned please.
Panes are incredibly useful and a “I didn’t know I needed it” kind of a feature - I had been opening Workflowy in browser and app to work side by side, so panes are totally welcome.
One pain point - or pane point if you will - is that opening a new pane for a total of two panes scales to fit the screen. Perfect, no notes.
Opening a second pane for a total of three panes spills over the edge of the screen and maintains the 1:1 down the middle scaling which is too wide for the viewport. I understand panes would quickly become too narrow to be useful as more and more are added, but I think scaling to accommodate up to four panes on a screen without having to scroll horizontally would be the final polish to make this feature perfect for me.
Apologies if I am missing something or if this has already been covered.
I might be misunderstanding, but I think you can do this already, see Command Palette | Workflowy Help
It makes a great kanban, great addition. the other features compliment it well (tags, collapse to hide columns, dates)
I would like to see another more efficient way of showing children in a sub-list. see my other post peek option.
Sensational function! It fits my brain perfectly and has completely transformed my workflow. Would love to see new panes the same width as the old panes automatically within the same page width, instead of making the whole page wider and wider. Thanks!
Interesting difference of opinion between those of us who would rather keep panes at their current width and scroll as needed for new panes, vs those who would like to shrink the pane widths whenever a new pane is added (up to a point, of course).
Perhaps an option between these, and/or a command to resize all panes to same width?
Same fore me: I love this feature. It is so incredibly helpful for rearranging huge amounts of texts. Now I have it and entered a whole new level of workflowy usability without getting complicated! Great feature!
I thought panes could be what I wanted, but in the end 2 or 3 jusxtaposed windows of chrome each with multiple tabs are more convinient.
An option for same-size panes when you open a new one or jump link to one would be much appreciated. Even if it pushes to the virtual space to the right of the visible window. Back to early days. Personal opinion: the current process is so anti-Workflowy simplicity.
