What I realized on macOS: When I have Workflowy in full screen and split mode with another app, the traffic light controls vanish. Even after I undo splitmode and close the other app and only have Workflowy left in full screen, the controls don’t appear again. The only way to minimize the window is to quick the app with CMD+Q and re-open it.
Hi Adrian! It is working fine on my end. Which versions of macOS and Workflowy are you using?
Also, if you could record a short video showing the issue, that would be really helpful.
Sure, here are two recordings: The first shows one behavior, when I close one app and Workflowy stays in full screen without the controls.
The second video shows the aftermath of closing another app from split screen - there Workflowy kind of just hangs around on the desktop without being able to move it.
macOS 27.0.1 - will update tonight to 27.2.
Solved in macOS 27.2
