This is on mac and on the web, used to be a lot more options and such.
Hi @jamiecropley thanks for your question. We recently pushed a change so you’ll find the menu in the left-hand sidebar by clicking the Workflowy logo.
I clicked everywhere except for there lol.
Noted and thanks for the feedback.
Hace poco detecté que se actualizó y la ubicación quedó en el sector izquierdo, según se indica en la siguiente imagen.
I have a simple question: Why?
I think it probably had to do with the recent panes feature. Since each pane has its own menu bar I’m guessing some of those controls needed to be split so each pane could have them and then things like settings had to go somewhere else so the rightmost panel wasn’t the odd one out with an extra settings button. But that’s just me guessing.
