Workflowy Desktop MCP
Connect an external AI tool using the MCP server built into the Workflowy desktop app.
Workflowy Desktop MCP lets AI tools running on your computer read, search, navigate, and update your Workflowy.
When to use
Use Desktop MCP when you want an AI tool to work directly with your Workflowy content. It’s useful for searching across your notes, summarizing project notes, adding tasks from an AI chat, and reorganizing nodes.
No API key is required, and the desktop app authenticates using your signed-in Workflowy account.
Note: Desktop MCP is only available in the Workflowy desktop app.
Steps to connect
Before you start, make sure you have an AI tool that supports local MCP servers over Streamable HTTP, such as Codex, Claude Code, Cursor, or VS Code.
  1. Download or update the Workflowy desktop app
  2. Open the Workflowy desktop app and sign in.
  3. Open the More Menu and select Settings.
  4. Scroll down to the MCP section.
  5. Enable Local MCP.
  6. Copy the generated Connection Link.
  7. Add that link to your AI tool’s MCP settings using Streamable HTTP.
  8. Your AI tool can now access your Workflowy notes.
  9. Keep the Workflowy desktop app running while you use the connection.
MCP clients use different configuration formats. In the client’s MCP settings, create a server named Workflowy, choose Streamable HTTP or URL transport, and use the entire Connection Link as the server URL. Do not remove the private token from the link.
Security note: Workflowy generates a unique Connection Link for your AI tool. Treat it like a private key and only paste it into AI tools you trust. You can disable Local MCP or close the Workflowy desktop app at any time to stop access.
Examples
Your AI tool can use MCP to read, search, and update your Workflowy notes, which opens up many useful ways to work with AI. Here are a few examples:
  • Search your notes on a specific topic
  • Ask your AI to summarize notes under a project node
  • Store the output of an AI chat in a note for safekeeping and reference
  • Add tasks to your today list from an AI chat
  • Move completed tasks into an Archive node
  • Attach files to a project node in Workflowy and have your AI read and analyze them
  • Use Workflowy to control your AI assistant. For example, ask your AI to watch for a specific #tag. When you add that #tag to a task in Workflowy, your AI can work on it and report back.
Troubleshooting
  • If tools do not appear, restart your AI tool after adding the Connection Link.
  • If the AI tool cannot connect, make sure the Workflowy desktop app is open and Local MCP is enabled.
  • If Workflowy says MCP could not start, another app may be using the default port. Change the port in the MCP settings and copy the new Connection Link.
  • If you switch Workflowy accounts in the desktop app, the MCP server follows the currently signed-in account.
  • The port must be between 1024 and 49151. After changing it, save the setting and replace the old Connection Link in your AI tool.
Stop access
Disable Local MCP to stop the server. Closing the Workflowy desktop app also makes the connection unavailable.
If a Connection Link has been exposed, disable Local MCP. Changing the port makes the old URL stop working at its previous address, but it does not rotate the private token in the link.
If you need a local cache, multiple accounts, terminal access, or deeper automation, compare the third-party tools. To see every AI path, return to Use Workflowy with AI.
