Hey there Workflowy folks. We have a bunch of exciting updates for you this week. From a quick add command on desktop, to a new dark theme, and a lot more to make your Workflowy experience a little bit nicer! Check out the full change log below and let us know what you think and what you’d like to see next.
Quick Add on Desktop Press Win+Alt+N (Windows) or Opt+Cmd+N (Mac) to open a lightweight panel for capturing thoughts from anywhere. Supports Markdown, auto-inserts clipboard text, strips HTML to Markdown, and grabs page titles from links. Notes land in your Inbox.
Use the new "/Move To Child" Slash command to quickly move a bullet under another.
Pro subscribers with Labs and AI enabled can now use Smart Nodes – a new node type that generates content to help you plan, summarise, draft, and create inside Workflowy. Try it with /ai or from the Turn into… menu.
New theme: Neo - When Dark isn’t dark enough.
You can now backspace into a slash command if you make a typo while searching for one. For example, typing “/mtv” isn’t recognized as a command and exits slash mode. Press Backspace — you’re back in the game with
/mt, and slash mode is reactivated. -
Fragments like “main.py” (and some other common file extensions) are no longer parsed as URLs unless they include a protocol (e.g. https://main.py). You can now manually unlink any existing “.py” in your outline (automatically doing this on our side would be too risky). Let us know if you come across any other cases where file names get linked unintentionally.
Other
In Markdown Export, To-do items are now rendered as
- [ ]and- [x] -
http://wwwandhttps://wwware added as exceptions and no longer parsed as a valid URL -
Links inside
code snippetsare now ignored — for example,example.comwill be rendered as plain text instead of a clickable link in all new snippets. -
Dates added by autocomplete no longer have weird spaces.
In addition to pressing Tab, you can now also click the popup that appears when you type “today” to autocomplete the date
Children of starred bullets are now draggable in and from the sidebar.
The “gear” icon in the date auto-complete pop-up now correctly leads to the Dates section of the settings.
