2025.18 /Move to Date, Import Kindle Highlights, Fonts, Moon Theme, Calendar TLC, and More
/Move to Date
Type /Move to Date (or /Date ) when you need to plan, reshuffle, or punt things into the future (or drag them back from it). It’s also in the multi-select menu, because let’s be honest, it’s never just one thing.
Import Kindle Highlights and Notes
Import your Kindle Highlights and Notes directly into Workflowy to keep them safe and organized. No more worrying about your My Clippings.txt mysteriously disappearing (I’m looking at you, Paperwhite).
Get started here: Verification Required - Workflowy
Personalization
Six new fonts to make Workflowy feel more like home: ET Book, IBM Plex Mono, Inter, JetBrains Mono, Lexend, and Open Sans.
New Moon theme : Soft, warm colors that are gentle on your eyes during those long work sessions. Hmmm. Smooth!
Free for all users, available in the Settings.
Calendar TLC
  • When you disable date groupings (Weeks, Months, Years) in the Calendar Layout menu, any nodes without calendar dates will automatically move to their nearest parent node.
  • Disabling “Friendly” date names in the Calendar Layout menu now works as expected.
  • Calendar layout changes now include a confirmation prompt before moving undated nodes, giving you a heads-up before any changes are made.
  • When moving a dated node with dated children, only the parent moves to its new date location. The children stay attached to the parent so they won’t scatter to their own dates.
Quality-of-life Improvements
  • The “Home” button in the sidebar now navigates to your home page instead of expanding/collapsing the section.
  • Redesigned Export pane with a cleaner button layout and improved mobile experience.
  • Pasting a URL over an existing URL link now updates both the link destination and display text.
  • Fixed GPU performance issues on macOS Tahoe in the desktop app.
  • Improved keyboard shortcut support for external keyboards on iOS.
  • Indentation now displays correctly when selecting nodes in mobile search mode.
Many thanks for all of the updates and fixes!
Hi there!
I have a question about the Import Kindle Notes feature. This sounds awesome, but I don’t use Kindle on an actual Kindle reader - instead I use the Kindle app on my Android phone and tablet. Is there any way to find this “My Clippings.txt” file on an Android, or would there be some other way to import the notes??
Thanks!
Kat
