2025.8 – Patch notes
date sorting blog
Hey there Workflowy folks, we have a bunch of nice updates for you this week. We hope you find them useful and look forward to more!
Improvements
  • Sorting now correctly recognizes dates at the start of bullets.
  • The Divider is bolder and easier to spot.
  • The Date Picker Range toggle respects your preferred week-start day.
  • Markdown paste now supports [ ] todo syntax.
  • You can now search for Dividers using is:divider .
  • Color highlighted text now exports with <mark> tags in OPML.
  • Completing a Mirrored bullet shows the satisfying completion animation.
  • Mentions no longer clutter your sidebar if you’ve turned that off in Settings.
Fixes
  • The ‘#template’ button no longer hijacks your cursor when arrowing past it.
  • You can’t Mirror or create Backlinks to the Home bullet anymore (for good reason).
  • The /template slash command now works on zoomed-in bullet titles.
  • Backlinks now behave on macOS 26.
Let us know what you think!
Really love it that there is so much active development. Thanks guys!
This is wonderful! One feature that would make a big difference is improved date recognition—specifically when typing at the start of a bullet point.
Let me explain:
If I have a bullet like:
Buy milk at the store
…and I want to prepend it with a date, I currently have to do the following:
  • Type “today”
  • Press space
  • Hit the left arrow
  • Delete the “y,” retype it
  • Press tab
Or—I’ve just realized a slightly better way:
  • Press the space bar
  • Type “today”
  • Press tab
It would be amazing if the system could recognize a date even when typed directly in front of the text—like this:
todayBuy milk at the store (no space between)
That small enhancement would save me so many left arrow taps. I regularly add dates to completed tasks at work so I can sort them later—especially at the end of the year when I need to show what I’ve accomplished. Right now, each completion involves this small but repetitive bit of friction.
It’s probably a low-priority suggestion, but I figured it was worth sharing!
Hello @cameronjpeterson.
Please check it out, is it what you meant?
Yes! Exactly! How did you do this?
Well, I just asked a programmer to write some code to make it work this way. It’s on its way to be released (we usually release on Tuesdays, but had a hiccup this week). You can also try it now on beta.workflowy.com.
@anatoliy how did you put that date format with the week number?
Based on the moment.js documentation, I suspect his custom date format (in settings) is [[]w[]] YYYY-MM-DD - dd. The w adds the week of the year. All the brackets are there to get [ and ].
Yes.
And you can also escape the square brackets, this works too:
\[w\] YYYY-MM-DD - dd
Thanks @anatoliy
is there a way to a a W (letter) before the week number?
Yeah, you can escape the W:
\[\Ww\] YYYY-MM-DD - dd
THANK YOU! Oh, this is soooo wonderful for me. I really appreciate your attention to this small detail!
I have a question about date recognition!
What if I get a huge list from someone. Where each line begins with date in this format dd.mm.yyyy .
And I copy-paste it to my Workflowy node. And Workflowy didn’t recognize dates at all!
It looks like just text. Therefore, the found dates feature didn’t work.
How can I tell Workflowy to recognize this text as a date object for the whole list?
