2026.02: Quick Add for Android, Calendar/Today, Numbered Lists, Code and Quote Blocks, and more
android-quick-capture
  • Capture thoughts instantly with Quick Add for Android. Get ideas out of your head and into WorkFlowy, then get back to that much more important thing you were doing.
  • Long-press the WorkFlowy app icon to access Quick Add, or add the widget to your homescreen for faster access. Press ‘Enter’ to turn following lines into sub-bullets.
  • Supports text and links and Android-only for now.
Calendar / Today
movetotoday
  • Drag nodes to the Calendar icon in the left sidebar to quickly move them to Today.
  • The Calendar Picker now includes Found Dates so you can see what’s coming up.
  • Found Dates now supports Date ranges, with nodes appearing for each day.
  • Found Dates now show in mirrors of the ‘Today’ node.
Numbered Lists
numbering-mirrors
  • Turning a numbered node into another type now updates properly in Mirror copies.
  • Fixed wrapping issues with 4-digit and longer numbered lists.
  • Numbers at the start of bullets from before the Numbered List item type are now preserved when converting to Numbered Lists.
Quote and Code Blocks
code-block-formatting
  • Converting Code Blocks & Quotes back to another item type now properly separates line breaks into individual nodes.
  • Converting multiple nodes into a Code Block or Quote now combines them into one block with line breaks.
  • Code Blocks display # and @ tags properly
General Fixes
  • iOS: Searches using quotes (“”) now work with Smart Punctuation turned on.
  • iOS: The Copy button in the Export screen now works reliably.
  • Fixed a bug where applying colors to hashtags with double quotes would make that color unavailable for text highlighting elsewhere.
  • Fixed text wrapping on Todo nodes with long text.
  • Fixed scrolling in the Add from Template search menu.
  • Mirrors are now highlighted when using a nested search.
  • Improved case sensitivity handling for languages like Turkish
  • Fixed unexpected behavior when copying colored text
Doc Changes
