About Workflowy Desktop MCP
Workflowy desktop now comes with an integrated MCP server. This is the recommended solution for integrating with your local agents: it interacts with the tree directly in the desktop app, which is much faster than going through the backend API and is not subject to the API rate limits.
Known issues
  • Claude Desktop insists on “https” (read further)
Setting up
  • Open Workflowy settings
  • Locate the MCP section and toggle the server on
  • Copy the Connection Link and give it to your local agent
Setting up Claude Desktop
Claude Desktop insists on using remote MCP (Connectors) and treats the ability to add a local MCP as a developer option so the set up is a bit more involved.
  • Install NodeJS from the official site: Node.js — Run JavaScript Everywhere
  • Click “Developer” in Claude Desktop settings’ sidebar
  • Click the Edit Config button to open the config folder
  • Open the claude_desktop_config.json in any text editor
  • Add the following lines to the config and save the file
+  "mcpServers": {
+    "workflowy-mcp": {
+      "command": "npx",
+      "args": ["-y", "mcp-remote", "MCP_LINK_FROM_WORKFLOWY_SETTINGS"]
Then restart Claude Desktop so it can pick up the config.
