Add mirror creation/deletion to MCP integration
I’m currently trying to integrate it via MCP with another note-taking style app (Sandbar Stream ring specifically) so that my thoughts don’t get too fragmented. Right now it has most of the functionality I need, except that the agent can’t mirror items via MCP.
I’m specifically wanting to use this to track open TODOs by mirroring them from my daily bullets. I could do this by hand but it sort of defeats the purpose.
Ask: add an operation to create a mirror of an existing node under a given parent (for example { “mirror”: “<source_id>”, “under”: “<parent_id>” }). It would also help if tree_seek showed when a node is a mirror and the ID of its source.
I have the same need.
