Learn to use advanced search functions to find anything in Workflowy.
When to use
Search in Workflowy helps you find anything, anywhere - instantly. Just start typing, and Workflowy will surface matching bullets across your entire account.
You can combine keywords, tags, dates, and filters to zero in on exactly what you need. It’s fast, powerful, and designed to keep up with even your biggest outlines.
Basic search operators
Search operators are characters or commands you can use to perform special searches. Most search operators can be used with all types of searches (text, tags, formats).
Exclude something: You can use the minus sign “-” to mean NOT. Place the minus sign before the item you want to exclude.
For example, use “-#high” to search for all items that do not have the #high tag.
Search for alternatives: You can use “OR” to indicate that you want to see results for one thing or another.
For example, use “@Steve OR @Lisa” to search for items tagged with @Steve or @Lisa.
Search for text
Workflowy will update in real-time with any matches as you type. By default Workflowy will also show partial matches. For exact matches, put your text in quotation marks “”.
- Click on the search bar
- Start typing the text you’re looking for
Search for tags
- Type out the # or @ tag
Search based on format
You can search for items based on their type, such as todos, shared items, and images.
There are several search operators you can use to search based on an item’s format. Below are some examples.
is:
has:
text:
highlight:
- Type one of the four search operators (
is:,has:,text:, orhighlight:) - Choose a format to search for
Search for a date
You can search for items with date tags using specific dates, natural language, or date ranges.
Specific date formatsMM = month, DD = day, YY = year, HH = hour, mm = minuteMM/DD
MM-DD
MM/DD/YY
MM-DD-YY
MM/DD/YYYY
MM-DD-YYYY
Natural language datesToday, Tomorrow, Yesterday
This week, Next week, Last week
This month, Next Month, Last Month
This year, Next year, Last year
- Click the search bar
- Type a specific date or a natural language date
Search for a date range
You can also search for a date range to find all items with date tags that are within that range.
MM = month, DD = day, YY = year, HH = hour, mm = minuteMM/DD - MM/DD
MM/DD/YY - MM/DD/YY
MM/DD/YYYY - MM/DD/YYYY
You can also use the search operator “date-after:”
- Type a date range
Nested search
Hierarchical search lets you use the “>” search operator to filter items based on the content of their ancestor nodes. In other words, it lets you use information about the ancestor node to narrow down your search. Nested search supports multiple words so things like “Projects > Write draft -today” will match nodes containing both “Write draft” and “-today”.
Note: There needs to be a space between each item and the “>” search operator. So for example, A>B would not work but A > B would.
This diagram shows the ancestors and descendants of the green bullet.
- Click the search bar or press ‘esc’ on your keyboard
- Write a string or property (like is:complete) to specify something about the parent of the item you’re searching for
- Type the “>” search operator to turn the search into a hierarchical one
- Write a string or property you’re trying to filter
- Optional: Continue using “>” to narrow down your search even further
Here’s a simple example that shows the usefulness of a nested search.
Example - Web agencyIn this example we have a list of projects for a web agency. Say we want to see all tasks assigned to a team member “@sam”.
This search would show us all the todos for “@sam”.
And if we wanted to narrow down the search and only look at the SEO related tasks, we could do that with a nested search of “SEO>@sam”.
We could narrow down the search even more by specifying we only want to include projects that are “#high” priority with a search of “#high>SEO>@sam”.
Other search operators
Workflowy has an ever-expanding set of search operators to help you find exactly what you’re looking for.
By default, Workflowy uses a partial fuzzy search to help you find items even if you don’t remember it exactly.
Basic logic / Boolean
(space between words) - serves as AND, will search for both items connected by the space
OR - Searches for items containing either item
-(minus sign) - Serves as NOT. Excludes the item with the minus sign from the search
"…” (quotes) - Works as an exact search. Only returns results if what’s in the quotes matches exactly
Format / type / property-based operators
is: - Select items by type or state (is:complete, is:backlinks, is:shared)
has: - Items that have a certain component (has:file, has:note, has:tweet)
text: - Search for text with a specific text styling, formatting, or color
highlight: - Search for text based on highlight color
changed: -Search for items based on when they were last changed
in:note:- Search for items based on location in item (backlink, note)
