Apple Shortcut to Dictate to specific node in WF
A link to an Apple Shortcut that allows using Dictation to add content to a specific node in a Workflowy outline is attached.. It’s named “WF Dictate to InBox TEMPLATE” but that’s just a name.
There are two Text Actions to modify in the template.
  • your Workflowy API key. A comment in the shortcut shows where to get the API key.
  • the Internal link to the node where you want the dictated text to appear.
Both are labeled in the template.
Change the name of Shortcut to reflect the name of the node you choose.
The shortcut can be run from your computer or using the Action Button on the top left of iPhones (iPhone 15 and above)
Notes:
This shortcut uses the Record Audio and Transcribe Audio Actions because the Dictation Action would not work on my MacBook Pro for some reason.
One of the text actions modifies the dictated text by adding the date to the beginning of the text and a tag “#dictated” to the end. Both of these are clearly shown in the Text action and both can be deleted or modified to suit your needs.
I’ve found it very reliable and useful.
