The status bar text color now properly switches to white when iOS is in dark mode and Workflowy’s theme is set to “System”.
The
dd D.M.Yformat is correctly recognized when entering a date (let us know if you have trouble entering dates with other formats) -
The ability to paste internal links over selected text is restored.
“file.md” is no longer auto-linked unless it has a protocol. You’ll need to manually unlink existing “file.md” links.
Numbered reference lines like [1] see source are now preserved when pasted — WorkFlowy no longer treats them as completed Markdown todos.
Pasting links over selected text in code blocks now correctly replaces the text with the link.
When you create a board, a blank child bullet is now added automatically so it looks like a proper board from the start.
You can now uncheck Window > Quick Add in the desktop app to disable the global quick-add function and release its hotkey.
WorkFlowy no longer leaves behind a ghost process after being closed — fixes an issue where the app wouldn’t relaunch unless the lingering process was manually killed or the system was rebooted.
Pasting code from the Gemini editor (and potentially others) no longer results in weird empty lines.
The ability to turn bits of text into
inline code snippetshas been restored, both via the hotkey and the context menu. -
It used to be tricky to get back to editing your search after selecting a sub-filter. Now, you can just click the search text to close the sub-menus and keep typing.
Thank you, @rodolfo for this and all the recent patch updates. It’s fun to see the progress and I get reminded of better ways to run my day in WorkFlowy.
Great stuff, thanks!
these changes do not appear in the “what’s new” section of the workflowy app, is that on purpose? The most recent update I see is from Jul 29th
We’re working on reorganizing this a little bit. That’s why you’re not seeing the latest patch notes in the app. But we should get that sorted out sometime soon.
why is file.md a hyperlink in this post?
That’s just how the system we use for this forum handles things it thinks are links - so the same issue we had in Workflowy!
