When I have a few panes open, and my focus is on the 2nd pane (basically pane, other than the most left one), when I push Alt+Shift+0 or Alt+Shift+9, I’m expecting to navigate within the current pane, I’m focused on. The same with actions move out, select all, they apply only to the 1st pane, but should be in the currently active one.
However, the action is applied to the left-most (1st) pane, which is very confusing.
The same thing (and often not consistent and quite strange) happens when I try to navigate on the currently active pane (again, 2nd+) using Alt+Down/Up/Left/Right hotkey, sometimes it works, but sometimes the navigation action is applied to the left-most (1st) pane.
Thank you for your consideration!
