Command Pallette / Shortcut Menu (Opt+W) doesn't work on Mac
Was trying to test out your new shortcut menu / command pallette on the mac app by the use of the suggested ALT+W shortcut, which would be OPT+W on mac? However when i invoke this shortcut all I get is the ∑ symbol instead :see_no_evil_monkey: Is there any way this could be re-mapped to something more memorable CMD+P maybe
Some features require the beta version of the app which you can download here
@rodolfo I have the beta, also on Mac and not able to open the command palette using any combination of keys I can think of. any ideas?
Beta on the web or beta mac app? On the web it should work unlesss there happens to be a conflict with a browser keyboard shortcut. And on the desktop it will only work if you have the beta version of the app which is available here - Workflowy Downloads
Following up on this — I’ve tried on both beta.workflowy.com and using the latest Mac beta (4.3.2606152345-beta [desktop, mac]) and I’m also just seeing the ∑ character when trying to access the command palette on a Mac.
Is there any update on this? And anywhere I can read more about this feature? It sounds incredibly useful!
The default hotkey for the CP is Alt+Q on Windows, so I expect Opt+Q on Mac.
Thanks for the suggestion, but I’ve tried every combination of [Option, Control, and Shift] with [Q and W], to no avail.
@mihira Try using /cp - Customize Hotkeys and set it to what you want. A node is added to your WF. Example below where I set it to Alt+E.
Thanks so much, @calsi. Your suggestion helped me realize that not only did I not have Slash Commands enabled in settings, I didn’t have Workflowy Labs enabled either. :expressionless_face:
I was able to get Option W working, and, using your tip, I could customize the keyboard combination too. Thank you!
You are welcome, glad it helped,
I’m not able to use this on Mac or the web beta.
Was this removed? I want to test the OCR feature.
Do I need to have a subscription?
