Configurable Move To priority
When I use “Move To” the moved item ends up as the top item in the target list. I’d prefer for it to end up as the bottom item in the target list. Can we have a configuration setting for this? Or even a “/move to bottom” command would work.
Anatoliy implemented this about a week ago (initially beta, now production). It’s a toggle switch via a slash command: /priority
@jodmarch the problem that this is one node by one node.
It would be nice a global selector
I like the option to change this individually, but there should be a global setting as well.
