Dark or light text on highlights in Neo theme?
Deciding whether to change it or leave it as is.
I’d prefer light text. Been missing it ever since switching to Neo
Light text and a greener green
I like both, but I still don’t use Neo because when doing a search, if the result node has tags, the tags are barely a different grey to the search result grey box.
So one of the two needs to be a different color. In dark mode the search result box is blue.
I actually do NOT like the search result box, I would prefer not having it.
The search highlight color should be much lighter in the next update.
I’d keep light text but make much darker the highlight. I can see it has transparency, so maybe just make it more transparent to reflect the background.
In case of green this works for me #8dbd6a99 → #8dbd6a40
