Data for productivity review and predictability
As I really believe WF can be the sole app for my productivity, Data calculation and exploitation is terribly missing :confused:
For a specific node, allow calculation (multicriterias) :
  • on dates : start date - end date - special deadline - duration
  • item Sum (by node and sub-node)
  • data from the specific node (see below)
For specific node, allow data:
  • duration (can be used as capacity)
  • dates : start, end
Display dynamic info for a specific node:
  • display if SUM durations all sub-nodes is <= or > duration parent node => that way, it helps you to refine and optimize by learning, what you can take in your day (or project) for instance
  • display a specific board view with graphs in order to help making decision and adjustements throught different topics (perso project / pro etc…) => show that for the week ahead, you need to re-arranged blocks / tasks or split them because there is overload
Ideally, a new dynamic timeline/calendar view (selecting timeframe scale and specific nodes to compare) : help you to adress bottleneck, overload, and projection of when things gonna be done.
my dream :slight_smile:
Hi @m2xpro
This sounds like it needs an app of its own :grimacing:
How would you describe this in its simplest form?
There were a calculist app. Very similar to the functions described above.
Hehe yes maybe but would be so great having little data about productivity natively within wf!
A simple form… need to refine it to figure out the mvp …
Oh really ? Thanks for sharing ! And do you remember the name of this or those app ?
And how do you “link” things between et and this app ? Or it is totally another tool using in // with wf ?
I mean the Calculist.io
A screenshot to illustrate.
