[Feature Request] Disable Spell-Check on Code
Text inline and block code (single and triple back-ticks) often contains perfectly valid text which the spell checker doesn’t like.
Please add a spellcheck="false" to the containing HTML tags so my notes aren’t covered in red squiggles.
Thanks.
Workaround
Thanks. Disables spell-check for the whole thing though and, since I run WorkFlowy in its own PWA profile, I could just disable spell-check wholesale it in the settings.
TBH, I could add a work-around with a mutationObserver if it bothered me enough, but it’s only a minor irritation so I thought a suggestion to improve it for everyone would be a better choice.
