FIXED! - Bugs: in the multi-pane mode, the beta has too many bugs
the cursor bug in beta
In the multi-pane mode of beta, pressing Enter creates a new node, but ## the cursor still stays in the last node/line.
4.3.2610011554 [beta, chrome-154, mac]
the new node is created but not rendered (displayed) until about 15 seconds have passed; after pressing Backspace from the new node, it takes a second or two for the new node to disappear.
Likewise, after pressing Backspace from the new node, it takes a second or two for the new node to disappear.
All confirmed.
confirmed 4.3.2610021231 [beta, chrome-154, win] but only when side panes are open
Actually even worse in 4.3.2610021231 [beta, edge, win] – the new node is created but not rendered (displayed) until about 15 seconds have passed.
Or, alternatively, after pressing Delete from the end of the original node after the new one is rendered, it displays 2 copies of the original node.
All confirmed.
I don’t understand how you guys use this thing right now… without CMD+SHIFT 0/9 (back/forward) navigation shortcuts… that bug has been reported 50+ days ago and still not fixed… among a couple more !
BUG FREE EASY FIX
@bxc I’m not sure which bug(s) you are referring to?
The very severe “Press Enter to create new node” bug in 4.3.2610021231 [beta, edge, win] (just before the weekend, alas) has apparently been fixed in 4.3.2610071644 [beta, edge, win]. But this was perhaps released after your post?
Alt+left and Alt+Right (navigate_backward / forward) work for me for moving back and forth in pane history.
macos 15.xx , chrome 155, app latest…
It is generally helpful to have one bug per forum thread, and one bug per bug report. Otherwise the “fixed” state of the thread / report is not clear and is easily muddled.
That said, from where did you get that bug tracker screen shot???
@BXC
Hey, cmd+shift+0/9 bug has been fixed on beta (4.3.2610271109).
