Fixed! Bugs: Mirror Position Bug
In the multi-pane view, every time I click/zoom into a mirror (except in pane 1), it automatically goes to the original position rather than the mirror position.
video clip: Slack
“original position” and “mirror position” :
The left side is the original location (/swap origin):
Calendar > Daily Notes 2026 > September > September 2nd, 2026 > Test 1 > testing node
and the right side is the mirrored location:
Notes > Test 2 > testing node
I click /zoom into the mirrored one, end up with going back to the original location.
If I understand correctly, the issue is that, in pane 2+, when you zoom into a mirrored node, its breadcrumb path changes to the path of the original, so that if you unzoom, you go back to the parent of the original rather than the parent that you started with, as expected. It’s clear this is a bug because that’s not what happens in pane 1 (or with no panes).
Exactly
Fixed on beta.
Thank you so much.
